thank you!!cant wait to try it again and now a little bit wiser !!
Maritime said:Plastic primer is called Adhesion promoter and is different. I actually makes the plastic surface sticky to create a bond with the paint better, regular primer won't do that on plastic. That being said I have painted sidecovers with regular paint and primer and had it work just fine.
High On Octane said:Yeah, I don't think that was ever clarified. You only need to use adhesion promoter on bare plastic. If the paint already has a good bond, you just need to sand and prime. If the paint is flaking or peeling, then you need to strip and start from scratch. And you can use W&GR on base coat, but only if you need to and use it sparingly. really, the only time I use W&GR on base coat is when there is bad dirt in my paint and I need to wet sand it out. At which case I sand with 1000 and then lightly wipe it with W&GR, blow dry, and tack cloth, then back to base coat.
jpmobius said:No trick. They are sticky and seem like they would have to leave behind something dreadful, but don't worry. I just very lightly run a somewhat wadded up cloth over things immediately before I paint, and very lightly blow some air over the parts from the spray gun - though I realize you can't do that with a can. For me I get the cleanest work focusing on keeping the area very quiet and still. I clean up the shop and cover everything I want protected from over-spray, set everything up exactly how I am going to paint, get out all the tools and materials I will need, and make sure I am absolutely ready in every way. Then I leave the shop closed up and undisturbed for a few hours. When I come back, I am careful to disturb as little as possible, tack off the parts and start painting. I have never been a pro painter myself, but I used to own an upscale paint and body shop and I get cleaner work this way in my embarrassingly filthy home workshop than we generally got in our very fancy pro spray booth at the shop. Most contamination comes from trash off of the thing you paint blown off from spraying the part - important for cars, not really an issue for well prepped bike parts. It can come from the compressed air - not an issue with spray cans (they have other problems like spitting etc) so it is important to filter the compressed air. It can come from the paint itself so strain and filter the paint (again, not an issue with cans). You are right - All kinds of problems are related to the painter. Clothing, hair, dirt from the floor, shoes, etc. Especially bad because the painter is the only thing moving around which tends to shake loose any existing contamination. You have some degree of control over all these things, but even in a very still room there are little specs floating around in the air, and it can take a very long time for them to settle via gravity and are easy to stir back up. To a degree, spray cans have an advantage as you have no air line. Dragging the line around on the floor has to be bad! In the end, it is a losing battle - all you can do is to minimize the problem. That very obvious speck in your new paint is very likely too small to find if you try to dig it out. The paint massively amplifies the actual size. Fortunately the color you are using will hide most anything once you sand and polish the finished parts.
