orrible-64
Coast to Coast
Until next week. Learning how to use 1080 3m film
I'm getting upto 66mph on my gps which equates to 106kph - I weigh a healthy 100kg ). My kege seems to rev to about 9500. Mileage wise I'm at around 2600km so should be nicely loosened upBojer said:What sort of top speed are you getting now ? I put a 16T front sprocket on mine without even riding it with a 15T , mine is reluctant to rev much over 8000rpm (on the Kege anyway!) but I get a GPS top speed of exactly 100kmh on the flat , maybe some more miles will up that a bit ? Mine is running standard up jetted carb & airbox with the snorkel removed , OO racing downpipe and a straight through megga with a 1" end pipe fitted .
Marcusgarwood said:changed a majority of the engine bolts to stainless Allen heads …
Didn't have any problems getting the original bolts out but did have a few nervous moments whilst initially loosening them, surprised all of the heads stayed attached. Some of the corrosion had eaten into the bolts and reduced the diameter in places by 0.5mm!stroker crazy said:The original case bolts were definitely rubbish! Did you manage to get them all out without drama?
Several of mine required drastic measures.
I hope you remembered the anti-seize grease; galvanic corrosion between stainless steel and aluminium can have disastrous results.
Crazy
Marcusgarwood said:I used Duralac anti corrosive compound …
