lucaspa
I am trying to get a cb125s2 running but don't want to mess with the lights,accessories. So here is a brief synopsis of system.
There are 4 leads coming from the alternator. Green/red going to neutral, pink,white, and yellow. White connects to a yellow/white and runs to the headlight control. Yellow runs to headlight control and connects to the yellow/white when the headlight is switched on to provide more juice to charge the battery when the headlight bulb is on. This all then goes to a frame grounded rectifier. Pink goes directly to rectifier. Red/white comes from rectifier to charge the battery and a fused red is pigtailed from this to the ignition switch. The battery is frame grounded. A black (switched hot) then runs from the ignition switch and runs to power the system when it is switched on. The black runs to power various systems but of concern is the headlight and kill switch. The kill switch connects the black with a black/white to the coils.
My question is this. I want to run with no lights, switches (getting replaced) or accessories just to get her going and then add new control switches etc. I am wondering if I need to tie the white and yellow from the alternator together and then bypass headlight control connecting directly to the rectifier, or will this over charge the battery since there is no regulator? The rest of the system will remain unchanged except that when starting the bike I will by pass the kill switch (or purchase a simple one from radio shack) and connect the black/white to black.
I know this is long but it needs the detail. I have some concern about overloading the battery so any knowledge will be appreciated. Thanks in advance.
I have attached the wiring diagram which may help.
