JustinLonghorn
No Purple Hearts, No Blue Ribbons
Righteous.
I completely cut out the bottom of the tank. It was so fucked, I said fuck it. I'll make a whole new bottom that wraps the frame with strategically placed petcock locations, or possibly one in the center rear. I'm also looking at boat fuel cells or having a aluminum one made to fit. Then the tank becomes a tank cover that gets welded to the seat to form a unibody. 8)Tune-A-Fish said:If your still looking for a petcock plan, you could plug the existing ports with brass and cut them flush, then I have used a good sharp punch and poked hols in both sides as low as possible then open them just until a chunk of steel tube fits tight... the punch roles the metal inward and gives a nice weld grove with good meat to weld to. You could even flair it for a fitting or thread it with a die, but then I just run both into a Y fitting then into a remote Petcock.
deviant said:I completely cut out the bottom of the tank. It was so fucked, I said fuck it. I'll make a whole new bottom that wraps the frame with strategically placed petcock locations, or possibly one in the center rear. I'm also looking at boat fuel cells or having a aluminum one made to fit. Then the tank becomes a tank cover that gets welded to the seat to form a unibody. 8)
So damn amazing. I want that so bad.Tune-A-Fish said:GL1000 blower
http://randakks.com/products/supercharger-kit-for-honda-gl1000-or-gl1100
deviant said:So damn amazing. I want that so bad.
Fuckin' A. I should've asked. I'd be interested in a spare set if you decide to clear some space.Tune-A-Fish said:I have a nice set of those rotors btw..
