TijmenK
Since I have a running bike again as soon as my battery is charged I'm looking into the three things I want to fabricate for my project.
[list type=decimal]
[*]A new dashboard.
[*]Housing for the switches on my handlebar(s).
[*]A battery box.
[/list]
I already drew up some plans for the dashboard and will do the same for the other two somewhere soon.
I've had a waterproof phone for some time now (Xperia Z) and never really made use of the waterproofness, I figured it would make a neat navigator / speedometer so I started looking into mounts and they're all butt-ugly. So I thought why not make a speedo / phone bracket crossover. So far I've come up with this:
This fits right onto my original triple tree and around my fork legs, has lights for neutral, high beam and neutral and a light- and killswitch, with a black and red waterproof cap respectively. The ignition switch will go in the battery box under the seat together with the starter button. A long bolt under the phone will clamp a piece of elastic cord on the underside which will hook behind the bolt on the upside. Still working on the shape and layout but it should be close to this. According to my stress tests 2mm aluminum sheet should be strong enough, but I might do 3mm just to be on the safe side.
So, what do you think?
[list type=decimal]
[*]A new dashboard.
[*]A battery box.
[/list]
