Re: 1963 Honda Benly C95 Restoration
OK - I'm an idiot (or rather, the wiring diagram is not as helpful as it might be). I had the key in the wrong 1 of 5 possible positions.
Turns out the top most position isn't 'off' like I thought - it's park, where you leave the bike with just the brake light on and take the key with you.
The middle 'flat' position is 'run' - key locked in and everything working.
One down from that is 'off' and key is removed - everything off.
Still not clear what the other two are - I think one is everything off but the starter/ignition to reserve as much juice for the engine.
Anyhow - once I figured that out, everything works as it should, including the brake light switch (yay!). Just needs a bit more loosening up, or I'll snag the one off the parts bike.
So tomorrow evening with a new gastank and petcock to get fuel to the engine, I may be able to start it up!
