1983 Honda cb 1000c
Electronics tray !!!
next antigravity battery!!!
Sent from my SM-N920T using DO THE TON mobile app
They can make a fair bit. I've mounted mine up inside the tail on an alloy plate with air all around it.
Lithium batteries work well. Get the reg/rec out of the pan and mount it underside of the tray in the air.
Looking good, I'm a bit of a stickler for wiring, even if you can't see it so would be nice to tidy and simplify it all.. also move the rectifier!
Kris, he is asking you to describe what is happening - what are the symptoms your are experiencing.
The old " i put pods on cv carbs and dont know what im doing!" conundrum! Its tuneable, dont worry. Start from stock, raise the needle, go up a few sizes in main jets. Will be alright eventually.
if its the carbs
i never believe that any more with dohcs
till i go thru the charging system and the ignition system
Don't respond fast if I hit the gas is weird symptom . I took it for a test drive the other day and I got into the highway and it went off on me I press the gas and it wasn't going nowhere , my spark plugs are good it showing this Burning property....
