diggerdanh
I looked for a long time for a similar cats eye taillight with integrated turn signals as well and didn't find anything I really cared for. I ended up adding turn signals to that tail light instead. I drilled new holes for mounting the plate above where the existing slots are. Then I cut slots on out to each side. Then bent the bottom half of each side down at a 90. That should leave you with enough meat to drill holes to mount mini turn signals on each side. The stalks on the mini turn signals should just be long enough so that the lights show on each side of the plate. On mine it looks a little "heavy" but I wanted the rear turn signals. You can see my results on page 2 of my build thread. But if they're blacked out to match the rest of your lights and the way your light is tucked in closer to your seat then it might look much better on yours. Just thought I'd throw out that option to you.
