thisisbuckwheat
Hey guys,
I'm posting here for a buddy that just can't seem to get motivated enough to do it himself.
He picked up a non-running Virago a couple of months ago, and we can't seem to figure it out.
We had it running briefly after bringing it home. Put some new plugs in it, and had to prime the cylinders, but it did run.
He then took the carbs off and cleaned them up, and now we can't seem to get it to go.
My initial thought is that there may be some sort of cracked seal in there that is preventing things from happening... Should he order a rebuild kit for the carbs? New gaskets, seals, etc? (I realize that he probably should anyway)
I am also operating on the vague assumption that there is a problem with the fuel pump, as the bowls are filling up (likely trickling down while it sits while we screw around with it), but it doesn't seem like it's getting fuel to the spark.
It has spark, it has good compression, and new plugs....
