CB750 No Plunger Hellride Freedom Machine
Re: CB750 No Plunger Hellride
I stripped the rest of the paint off the fender, ran the factory flat spot through the English wheel to match the fender profile and now I’m filling holes. When it’s done, only the round and oval hole above the square will remain.
Needs a little filler, but good’nuff.
Might not seem like much, but I added an inch to the fender struts and moved their angle to match the down tube in front of the seat. This changes the fender’s orientation so that it matches the wheel shape much more neatly. It makes for some nice filigree.
Much much better. I am a fan of matching the angle of either the downtube or the front forks.
That looks a lot better, guard fits the wheel nicely now.
Final post about the exhaust to finish up the tail pipe on the inlet...
Sweet child of mine... that looks cool. keep cuttin' and weldin'
I took some time off from working on the Mid-Ohio haul to make the chain tensioner. I machined the drum and welded an old gear shift lever to it and a cap screw to the shift lever. I machined a bronze bushing to insert into the drum, then on the backside I machined a delrin bushing to fill around the bronze.
In all but the last pic, the arm is basically straight. In the completed unit, I bent an "S" into the lever which centers the skateboard wheel over the pivot and moves it clear of the frame.
In this pic are all the components minus the spacer to go behind the skateboard wheel that centers it to the chain.
This is the backside of the tensioner, where the delrin surrounds the bronze.
Here's the unit put together with the spring from a kickstart mechanism. One thing that changes on the spring from what you see in the pic, I spread the first coil out to help put more tension on the spring and to help it spring back a little better. That may not have been necessary, but it doesn't hurt either.
Another view of the arm and pivot. Notice the drum isn't machined square, but instead has a curve to it. This helps the spring move toward the arm and keeps it from binding in front of the mechanism. It also gives it more throw, as the way the spring works the ID shrinks when the tensioner actuates. I didn't want the spring too loose, but too tight kept it from swinging very far and it would bind.
This is the pic of the completed tensioner. The arm is bent, which moves the wheel back toward the center of the bike. The arm is also shorter than in the previous pics.
Man, that is slick.
Looks like you'll have this on the road b4 I get my lazy azz out and fix my carbs, and get mine running again.
Nice work Eric.
Hey Irk, nice bike for sure, but what's the black coupe behind it?
Brodie said:
Wall art.
Haha. For now it is, Brodie. Except it's more the wall than the art.
It's a 1970 Plymouth Roadrunner.
A 21' long shelf? I have one of those but its a few feet shorter. ;D
