Thanks Joe,
I got the bike running today. The Pamco Ignition I got works great, i can't believe how simple it was to hook up. I should have my seat ready by next friday. I can't wait. I should also have the rest of my wiring doneby then.
All I now need is my brake/running light to put on my tag plate and a new set of signal lights for the rear. i don't like the one's I have at the moment.
Here is my seat pan before I took it to the upholsterer. I had to drill extra holes to prevent the vinyl from ballooning up when I seat down.
This is one of the only spaghetti photos I have available.
The bike today prior to firing it up.
Here is alittle clip. I still have to fix the usual starter spring on the bike, they are known for the little gear making that noise when the spring loses tension, or so I read. So that noise after start up is that little gear with lack of tension. Should be a quick fix.
I'm also thinking of running shorty's on there.
Anyhow, there is no revving due to the fact that I still need to shorten my throttle cables.
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/Sl4p2ZJmuFY&hl=en_US&fs=1&color1=0x2b405b&color2=0x6b8ab6"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Sl4p2ZJmuFY&hl=en_US&fs=1&color1=0x2b405b&color2=0x6b8ab6" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
