Author Topic: disc swap onto 77/78 CB750 front wheel  (Read 1212 times)
Offline spotty
  • Vmax...why,yes i think i will
    • spottys world of vmax (and great danes)
« on: Dec 06, 2014, 03:38:47 »
i seem to remember reading somewhere that the mounting hole spacing and offset are the same on stock CB discs and also CBR1000RR. obviously the CBR ones are going to be a whole lot bigger but thats not aa problem as i'm going to change to slightly later fork lowers so i can use real calipers (early 4 pot GSXR) with ally mounting plates and the GSXR m/cyl
if not, does anyone know of what modern ones (i.e LARGE) do fit onto a CB front wheel? i realise i could probably use stock ones drilled/grooved but if i'm going to do the calipers anyway i'd like to have modern 'buzzsaw' discs (see photo to the left of the same thing fitted on the Vmax with the GSXR calipers)to go with them
the GSXR calipers will get taken off the Vmax to use on the Honda and replaced with 6 pot Hayabusa calipers and m/cyl
ta for help, cheers
spotty
short fast loud, three things punk rock and vmaxs have in common
south of the border, down melbourne way
Offline Chuck78
    • my bike photo album
Re: disc swap onto 77/78 CB750 front wheel
« Reply #1 on: Dec 16, 2014, 20:39:52 »
scour ebay for info from the chinese aftermarket brake rotors that fit the cbr (some of the auctions have in depth specifications listed, some dont).  I did that for the 74mm and 78mm 6 bolt pattern rotors, as you can bolt the 78's directly onto Suzuki GS hubs and the 74mm 6 bolt pattern rotors can be redrilled to fit Suzuki GS hubs.  I found a wealth of info on different rotors to use for various swaps, all from Honda CBR's, VFR's, etc.  There were many that were not the 74 or 78mm 6 bolt PCD, so maybe one of those is what it takes for yours? I can't recall the bolt circle on the big CB's off the top of my head.
« Last Edit: Dec 16, 2014, 20:41:28 by Chuck78 »
'77 GS750 920cc, 4-1, GS1100E swinger, 18" Sun rims, Fox Factory Shox, twinpot dual disc, CR31, Yosh cams
'74 Rickman VR250MX
'99 Kawasaki KDX220 rugged terrain ripper
PROJECTS:
'77 Suzuki PE250B
"Pure Enduro" trail beast, ported, Wiseco, TüBliss, Fox Factory Shox/RaceTech
'76 Rickman CR GS1000-1120cc roadracer, Yosh cams&4-1, RF900R fork, Works piggybacks
'79 GS425 489cc Formula 500 racer, Tempter cams, GS650 forks, twinpot brakes, DID rims, GS1100E swinger, Fox Factory Shox
'77 GS550's 650-740cc susp&brake mods
Offline Aussie Steve
  • As useful as an ashtray on a motorcycle!
« Reply #2 on: Feb 11, 2018, 14:40:51 »
Hi spotty, I know this is an old thread, but did you work out a good substitute disc rotor? Cheers, Stevo
Sent from my Lenovo A6020a40 using DO THE TON mobile app
Bruce comes home from the pub and sees Sheila watching Gordon Ramsay's F%*#ing cooking show on the telly.
Bruce says; "What are you watching that shit for? You can't cook to save your life!."
To which Sheila replies; "So what? You watch porn movies, don’t you?"
