Author Topic: Ct70 build  (Read 26000 times)
Offline DohcBikes
  • Fuck You.
Re: Ct70 build
« Reply #40 on: Sep 09, 2015, 00:39:41 »
The engines are top notch. Dont even front the first time you ride it. Shit can get out of hand quick. Dont forget to rotate the engine with no fire several times before you start it, then ride it like you stole it to break it in. Use rotella T or a good break in oil. No synthetic.
Make sure the valves are properly adjusted
Awesome.
« Last Edit: Sep 09, 2015, 00:44:00 by DohcBikes »
burning bridges sometimes light the most productive paths
Offline clem
  • static fluff
Re: Ct70 build
« Reply #41 on: Sep 09, 2015, 14:00:27 »
Cool man. When I was in my shed last night I noticed that the exhaust that I have on the XR70 is a piranha, way better quality than the switch was. The more I see of this build the more I'm thinking that the Daytona might get pushed back for the CT.
Offline Tifun
  • Indy
Re: Ct70 build
« Reply #42 on: Sep 09, 2015, 16:18:30 »
Any pics of said exhaust?
KZ440 LTD Build: http://www.dotheton.com/forum/index.php?topic=61491.0
SOLD: CB550K Build Thread http://www.dotheton.com/forum/index.php?topic=42545.0
Quote from: Angela's Bonus Technique
whawhooshwhawhooshwhawhooshwhawhoosh
Offline Tifun
  • Indy
Re: Ct70 build
« Reply #43 on: Sep 09, 2015, 16:21:31 »
Awesome.
A buddy local who is known to build a handful of big bore CT bikes said the 140 Piranha has charging issues. I'm thinking of doing LED bulbs all around to lower amp/watt consumption. I've been on the search for a solution but haven't found anything appealing yet.
Offline Tim
  • Administrator
    • DO THE TON
Re: Ct70 build
« Reply #44 on: Sep 09, 2015, 16:24:52 »
Maybe I'll redo my 90 after I enjoy it a little bit more :)
Offline Tifun
  • Indy
Re: Ct70 build
« Reply #45 on: Sep 09, 2015, 16:52:30 »
Dang that's clean Tim. I'm digging that exhaust!
Offline Tifun
  • Indy
Ct70 build
« Reply #46 on: Sep 10, 2015, 23:21:48 »
Had some time tonight to go out and test fit a few things. Mainly the engine to the frame. Fits perfect without any modifications. I did notice the new carb has only one input verses the two outputs the gas tank has. There's also no fuel shutoff like the stock carb has built in. I'll need to find an inline fuel shutoff. I also suspect I'll need to get an auxiliary tank if I want to ride more than 20 miles. Anyway. Pics!
For those curious about the build quality of the engine. It feels equally as solid if not better than the stock CT engine. Everything fits where it's suppose too. No strange burrs and grind marks. It is raw however. I do expect it to yellow a little as it ages. Thinking of hitting it with that high temp 2 part engine epoxy paint for the case and powdering the covers.
Offline clem
  • static fluff
Re: Ct70 build
« Reply #47 on: Sep 14, 2015, 08:44:30 »
yeah it does look nice. I might have to pick up another frame and build a big bore and leave my current one stock. Are you putting street tires on it?
Offline Tifun
  • Indy
Re: Ct70 build
« Reply #48 on: Sep 15, 2015, 13:00:20 »
This one is getting a flat track looking tire. More geared for street/urban. I'll be getting a second frame and building another solely for the dirt. Most likely using the stock engine.
Offline Tifun
  • Indy
Re: Ct70 build
« Reply #49 on: Sep 15, 2015, 21:45:40 »
Took the forks apart and cleaned them up. That's the last of the tear down before powder.
Also found this oil cooler hidden in a parts box of random car bits from years ago. Should work perfect.
