CALfeRacer
Fat man on a little bike
Instead of boring everyone with a long backstory, the short story is that I decided to swap a 86 KX250 engine into a late 60's C2 frame for a class project. I've had the stuff laying around for just over a year now, and making it a school thing gives me an excuse to do it.
This is the only picture I have of the frame before I started. Mocked up with the 86 KX swingarm.
Since then I've removed the remaining mounts from the engine area of the frame using a cutoff wheel, plasma torch, and a flap wheel.
I was having issues with the swingarm pivot getting in the way of the motor. Since I'm probably going to use the KX swinger through the pivot on the back of the motor it was time for it to go away.
To this:
Which brings me to today. I'm trying to figure out how the engine is going to sit in the frame, but I'm not sure on how it should go so I'm posting it here to ask for some advice. The housing for the kicker is limiting me, it hits the frame on the back. Not sure where the swingarm pivot needs to be in relation to the frame since it is a fixed distance from the sprocket (since it's the engine case). I took a shot of two setups which seem decent to me.
These both give decent clearance of the kicker case to the frame, but there's a pretty big gap from the swinger pivot to the frame. Keep in mind these aren't a perfect representation, the frame is propped up and the engine is dropped from where it would be if it was in the frame. AKA the gap between the pivot and frame looks worse than it is.
Any thoughts on how the motor should sit are appreciated, I want to get to making mounts and welding next week. Thanks for checking it out and hopefully there will be more updates soon!
To this:
