Author Topic: 1975 Honda CB125S  (Read 8750 times)
Offline flamelspy
Re: 1975 Honda CB125S
« Reply #40 on: Jun 01, 2017, 10:59:51 »
I assume you put down a layer of plastic sheet to protect/allow for easy removal?
When molding the fiberglass on the frame?
I put some newspaper hehehe.
and used it to isolate/protect the gas tank too, since i needed it on place to shape it perfectly.
Works like a charm, and it's free!
Offline vwrabbit
« Reply #41 on: Jun 01, 2017, 12:07:51 »
That works!
Offline vwrabbit
« Reply #42 on: Jun 08, 2017, 09:09:16 »
Kind of got the coil sorted.  It wasn't bad.  Not sure why I wasn't getting spark.  Got it running again for a few minutes while I tried to sort out the brake lights, but now it won't run for more than a few seconds.  And as soon as I give it gas, it pops and shuts off.  And the interval keeps getting shorter for run time the more I try to get it going right after it dies.  I'm wondering if it's points.  Also need to double check the regulator/rectifier.
Offline vwrabbit
« Reply #43 on: Jun 08, 2017, 11:29:43 »
I also just replaced the float needle.  I wonder if float height would affect this?  Need to double check that.
Offline crazypj
« Reply #44 on: Jun 09, 2017, 15:49:15 »
You should always check and re-set float level when you fir new shut off parts
Best thing I ever overheard
Brian Morgan, 1982
Offline vwrabbit
« Reply #45 on: Jun 12, 2017, 10:09:49 »
Float level FTW.  I was checking it wrong.  Got the level set correctly and it's now running.  Thanks!
Offline vwrabbit
« Reply #46 on: Jun 20, 2017, 16:07:53 »
Ordered some Avon AM83's.  Current tires are old and not quite the right size (too wide up front).
Need to figure a way to remove the rear fender and remount taillight and turn signals.  Might just trim the fender up.
Offline crazypj
« Reply #47 on: Jun 26, 2017, 12:37:52 »
You need a smaller tail light, the original Honda one is huge.
I like the 60's style Lucas but prefer the 'raw alloy' to chrome plated
http://www.ebay.com/itm/Lucas-Style-Motorcycle-12V-LED-Tail-Light-For-Triumph-British-Cafe-Racer-Chrome-/262759607036?epid=2102678645&hash=item3d2db16afc:g:k28AAOSw6DtYTrBt&vxp=mtr
Brian Morgan, 1982
Offline vwrabbit
« Reply #48 on: Jun 26, 2017, 13:16:53 »
Definitely want a smaller taillight.  That one looks like it would work well.  I wonder how well that would fit the fender?
Offline crazypj
« Reply #49 on: Jun 26, 2017, 16:04:40 »
I've only fitted them to CB360's. Modified to fit over rear frame rail (like later 60's/early 70's Triumph's)
 I really should have taken a few measurements plus made a template to cut on it but I wanted to see it in position I just used a carbide burr
Brian Morgan, 1982
