Erskine
Over 1,000 Posts
beachcomber said:Looking good Steff ................. could I suggest a diagonal brace at the rear [ last pic ] from the top bend of the frame loop - approx 45 degrees down to the bend in the rear floor loop. Apologies if you already have this in hand.
I hadn't considered bracing those two points ..... if I did it would have to be demount-able in order to remove the rearwheel.
I have yet to try a rear wheel on the swinging arm to double check that the rear hoop allows enough clearance.
While we are talking rear ends, I dont know whether to go for a traditional rear mudguard mounted within the rear frame loop and padded on top for the passenger to lean over, or a fibre glass seat that spans the rails. what the sp on knee cups ..... guttering?
