santogd182
Hey guys,
I was working on getting my 1975 cl360 started over the weekend and I seem to be having issues.
Here is a list of what I have checked out/done so far:
1) All wiring for it to turn on and run confirmed working.
2) Cleaned carbs before putting the bike back together and I put the fuel tank back on and gassed it up with about a half tank. I confirmed that gas was indeed moving through the petcock and into the carb fuel lines but I am not sure how to check if gas is moving into the carbs while it is on the bike, any help with that.
3) Starter turns the motor over.
4) Coils hooked up and with the spark plugs are sparking when pressing the starter button and holding them against the engine head.
5) New spark plugs
6) Sprayed starter fluid into the carbs, and I get one or two loud backfires
7) Put a little gas (1/8 oz) directly into the cylinder and I get the same thing, it will backfire once and then nothing.
6) Pulled the stator cover and the points cover. Points seem to be working correctly but could use a little adjustment (would I be getting any spark if the points were way off?) I have not played around with the timing yet but that is next on my list.
I just wanted to see if there is anything else I could be missing. It seems like everything is in working order but I cannot get it start. I know there are probably a hundred of these threads and I have read through many of them with no luck so far, any help would be appreciated.
Thanks,
Chris
5) New spark plugs
Thanks,
Chris
