Spools on the CB750 swingarm?
belmont
Anyone put spools on the stocker swingarm? I don't have a center stand and it bugs me to work on the bike while on the kickstand.
I just did it. First thought was to use the bottom bolt of the shocks and use a longer bolt that also holds the spool - Its way to high to catch the stand. Then was planning on welding a double nut to the underside of the swingarm... but as I got looking, there is enough meat on the flattened section where the axle bolts, I just drilled a hole and tapped it. Then Voila... Spools and could delete the center stand.
