Soltesjoey350
21 years young, 1972 Honda CB350.
What are your thoughts?
xb33bsa said:the compression looks very near perfect don't try to fix it
as far as carburetion don't ask for help if you are running pods
xb33bsa said:well it looks carboned up rich was the plug taken out after a hard full throttle run plug chop ?
xb33bsa said:as far as the idle is your ignition all tuned up ?
plug readings are only really gonna tell you jetting is correct at high throttle run preferably wide open for at least a couple hundred yards on a hot engine then you kill the motor quick clutch in preferably rolling up to a place, take yer time,you can pull a wrench out and check the plug for a reading, thats a plug chop
once you let the motor idle it will get darker sometimes just plain black
xb33bsa said:well i had the pamco and it worked, until it didn't ???left me stranded...i sent it in for repair a year ago no word back :-[
.i switched back to points(get nos honda well worth the $40+ they cost,do not get cheep china points )
new points set correctly work great and you don't need to touch them for thousands of miles
Hahaha no I got that down! If the CB had a distributor I'd be all set on it too! I like to make sure I completely understand how to do stuff before I dive in :-[crazypj said:On Beetle?
;D
xb33bsa said:if the bike runs now,do not mess with the backing plate position and or mark where it is
swap out the points, gap them at .014" there is a tiny hash mark on the points cam where to set the points
then as long as the bike will start up,and run, hook up the timing light number 1 left
set full advance(run engine up to 3500 rpm when doing so) between the marks by moving points backing late
then hook up timing light to number 2 right cylinder and check full advance if it is off it is changed by adjusting points gap a bit,wider gap advances smaller gap retards
when swapping out points it is pointless and a waste of time to set static timing, just move on to the full advance setting,this is givin that the advancer works smoothly and has spring tension to smoothly return
Very true I will look into it more the idle surges big time going from 1500-4000 sometimes lolxb33bsa said:the factory service manual shows all that better than anybody can type it
