I was digging around the internet for something and came across the last GPZ pictured. I figured I would register and show some pics of my bike. Its not really cafe style but more of a retro race bike.
I will work backwards from what it currently looks like but first the specs. Currently weights 325lbs with starter, battery, turbo, exhaust etc. pretty much everything ready to run. My goal was/is sub 300lb bike. it dynoed 80hp at the wheel without the turbo setup. just under 23 degree rake, 3in trail, 11degree swingarm angle. 55% front weight bias with rider. 55degree lean angle before the cases hit...fox clicker rear shock. 89 gsxr 750 front end. 95 gsxr rear arm. Custom wiring harness and lots of other custom bits as you can image to drop 200lbs off the bike. stock frame(with parts removed), custom subframe from 3/4 DOM. I had this as a street bike in 99 mostly stock, then in 02 decided to do a wheel/suspension upgrade. 03 pulled it off the road. 06 put it back on the road with more mods. 07 pulled it back off the road. 10 decided to build a vintage race bike. quickly realized that my bike wasnt vintage legal anymore with a turbo and FI and all the upgrades so i started getting back to basics with it. No turbo or FI puts it from v5 into v7 heavyweight running with literbikes.. Started racing supermoto and its been sitting since...
another tail section i made and turbo setup.
closest it was ever to a cafe. tail plug and mold ended up being used on a cb360 cafe.
and here was the first real tail i made for it. This was its form when it went back on the road. except with dual dumps on it.
So you can make a light GPZ without swapping the frame, but you need to lose a lot of stuff off of it
I think the 82 tank lends itself better to making a cafe bike than the 83+ 750 but it would still be done. Could always use an 82 tank.
I did have measurements of all the stuff i swapped and removed but its on another computer that i havent hooked up since ive moved. The heavy things are the stock sub frame and all its mounts and brackets for things like the seat. Stock seat is heavy. Stock upper fairing bracket, upper, headlight and bracket, horns, clip ons etc. Center stand, stock dual exhaust, stock peg brackets, stock gauges. if you get rid of all that stuff you can drop a lot of weight. probably 10lbs came from the wiring harness and relays/fuse box i didnt use. A lot of weight dropping the stock battery for a smaller unit. I used a sealed battery from a yamaha xt225 and it cranked my motor just fine(decked head but only slightly higher than stock compression). I actually have a guy coming over today to grab all my old stock parts and he might make an offer on my bike. If not it will be finished one of these years
I've had it for 14 years. I would love a stock one to sit next to it in my garage
my plans are to use a gpz550 head and bump the compression up, smaller combustion chamber. Dry clutch, wasted spark and no starter. These should get me below the 300lb mark for a track day bike
Not sure why the pictures are double posting. I used IMG links from photobucket....
