79' CB750K Rebirth
Better use more than painters tape. I recently put in a SOHC engine in a restored bike and was scared shitless to scratch the frame (my first engine transplant), so I taped a bunch of hand towels to the frame and it worked perfectly. The blue tape wont do sqaut (in my experience) with engines and frames. Wrap it up!
thirsty 1 said:
http://www.cb750c.com/ Tons of good info. These guys are more into resoration and not custom jobs. Dont mention pod filters you wont get anywhere with them at this site. Good people though.
If you think the custom boys are a tough crowd, you'd better stay away from the guys over at cb1100f.net :eek:
Just kidding. ;) But they did lamb-baste some guy for taking a disc grinder to one of his shims ::)
Nice build tho. Best of both worlds - DOHC, and spoked wheels.
cheers
ian
Got a roller!
I thought about it but I think I might get a set of RC51 integratered tail lights to put in there. I'm still not sure yet though. I should get the engine in tonight or tomorrow so ? I could always do it later.
CrescentSon said:
Man I'd cut the frame rails and leave the seat pan just like that with some neoprene padding.
Well I finally got that big F'in lump of a heavy bitch engine in!! Jesus H! You'd think it put out 500 hp just from how heavy it is. :eek: Done bitching now.
It is nice to be able to sit on it and get a feel for how it's comming along...no more cleaning of the big parts YES YES YES!!
Had to take it all back apart so I could wrap the frame around it. It went in so nice and easy I couldn't hardly believe it..
Now on to carbs, wiring, and all that fun piddley shit@!
it builds like yours that makes me want to start over on mine but i'm getting to excited to get it on the road. i cant wait to see what yours is going to look like. us west coast boys(and girls) have gotta meet up and go on a ride together
Well it took me all most all weekend but I have my carb's cleaned and reassm/rebuilt. I used Original Pin-Sol to get all the crud out. Man that stuff works awsome!!! Brought the housings back to there original aluminum casting shine - Sweet!!! Bench sync. is do too!! Unfortunatly I might have to split the two halves to put in a "T" between carbs 2-3 because I didn't know about it until after they were together but oh well at lease I caught it before they were on....
On to the front caliper. I cleaned it and painted it but it looks like a butcher job. Needs a good sesion in the glass bead machine and then repainted.
biker_reject said:
Carbs lookin' good!
Thanks man you need to get that one of yours finished. That thing is looin' good. I can't believe the amount of polishing you did! Way more patients than I have. I did end up taking the carbs apart into to pieces to get the bowl vent T installed. A bit of a pain but then after that I had one of the needles leaking and a accel. pump squirter not working. Back apart again to open the ports and get the needles to seat. I suppose they'll leak again and I'll end up with them apart again...oh well! I really want the Gixxer carbs but the funds won't let me. Anyhow I got the carbs on along with the airbox after cleaning and paint. I think I'm up to about $600 bucks w/ the purchase price and registration so I guess I'm doing good!
It's pretty bad when my Iphone takes better pictures than my camera....
I also decided to take that big ass head light and bucket off and switch it for a 5" light. Just going with a tach only to keep it clean up top! Tank, seat, and wiring next.
I hear ya on the carb rebuilding! Ha! I didn't reassemble correctly the first time either! I keep hoping I did everything right. I think it took me at least three times to disassemble/reassemble them. Reminds me of when I decided to rebuild a Rochester 4 barrel carb on my Blazer years ago! I kept getting faster at the process. Today, I worked on the tach mount. It's made of a piece of 16 gauge steel and a major pain to work with. I think I'll have to make one out of aluminum. Still waiting on my rear set rods from Fast From the Past. Once those are sorted, it's on to the front brakes and undertail. The project should start moving again as the weather warms.
Thirsty, are those the stock VM42A Keihins? They look waaay different than mine. The floats are completely different too. Mine are solid plastic, yours look like they're halves with a metal bracket connecting them? Build is looking great so far by the way!
You have a set of carbs from an 80-82 if they dont have adjustable floats. There plastic where the needle hooks on right? One piece? You my friend, dont have to worry about float heights because you cant adjust them! From what I've learned there all the same they work on all DOHC bikes, except the 79 carbs have adjustable floats and some have pressed in slow jets which can be a real bitch to clean. Ya there VM42A's.
Well, I'll be damned. I'm just finding out all kinds of stuff about this bike I bought. Thanks.
