Mikuni vm20
JustinLonghorn said:
Did you get it on the cheap?
Yeah much cheaper than the unavailable VM20 from distributors like sudco. Mikuni has really taken a hit from the Japan economy due to the giant wave. They are out of stock on a lot of items at the moment apparently.
http://item.mobileweb.ebay.com/viewitem?itemId=221010066226&index=1&nav=SEARCH&nid=69041618258
Here is the link Justin. $74 plus shipping.
No flat slides here!
VM are round slide. Is that what you are looking for or a TM flatslide?
And big twins are in a class of their own. A little too much top end isn't always a good thing in powerbands or young ladies :)
Hey mate is that the one you are running on your cb200 now? If so how dose it go and did you have to modify the intake at all to get it on ?
I saw this one on eBay item num. 190681065866
But don't think it will fit.
Yes, running a standard flange mount vm20. http://item.mobileweb.ebay.com/viewitem?index=0&sbk=1&nav=SEARCH&itemId=221218839455 This is the same ones I am using. I did have to open the bolt holes just a little with a dremel tool to get them to work but there is plenty of material left to support the carb. I did not have to re jet them, but I am running k&n pod filters.They are listed as carbs for a Yamaha rx100 which came stock with vm20's. The listing number you gave are not the ones I used, appear to be vm30's. Hope this helps you out. Just let me know if you need any more info.
