www.townmoto.com
www.Moto-Madness.com
Author Topic: Comstars + gsx-r front end  (Read 10609 times)
Offline rs_ss350
Re: Comstars + gsx-r front end
« Reply #120 on: Jul 07, 2017, 15:39:49 »
Photobucket really pulled a fast one.....and they won't let me download my albums (over 12yrs worth, 4000 images) to go back and fix every post I've ever made. pretty irritating.
aw man that is a raw deal, holding your pics for ransom.  looks like they want $399 to unlock you!
thanks for reposting the pics, sent you a PM...
1979 CB750K - 10th Anniversary Limited Edition
1982 CB750K - Cafe/brat project under construction
1977 CB750K - another project!
Member of Moto Guild SF
Offline crazypj
« Reply #121 on: Jul 07, 2017, 15:44:00 »
I tried downloading my pics and it didn't work either. Yep, they are holding them for ransom and want $399 a year
Best thing I ever overheard
Brian Morgan, 1982
Offline rs_ss350
« Reply #122 on: Jul 08, 2017, 16:16:44 »
OK, so I have been thinking about this a lot - and I have to choose a new wheel.  I'm considering the old comstar from the GL1000, but am a little hesitant to do so without being able to measure the spoke width.  If anyone has a set, some measurements would be great! The caliper spacing is 40mm.
Ideally I would also want to use the matching rear wheel, with drum brake.  Does anyone know if that's possible or have you done it before?
I also started looking around at other mag wheels I might like to use, contemporary to my year model.  I came across the wheels from The Kawasaki KZ750, same model year (82).  I was lucky enough to have a guy working one right next to me in the shop this morning.  I measured the the rims and there is plenty of clearance.  I assume the process for fitting them would be the same as what has already been discussed here.  The only question, similar to above, would I be able to use a rear wheel from the KZ on my CB?
Thanks!
Offline focusinprogress
  • City Limit Moto:Parts-Service-Apparel (716)8038606
    • City Limit Moto
« Reply #123 on: Jul 10, 2017, 09:33:29 »
front wheel would be similar work yes. According to Partzilla, the rear wheel bearings for the '82 KZ750 are SKF6303 which are 17mm axle......your CB750 uses a 20mm axle.....
The part could be remedied with different wheel bearings, a quick search says 1204 or 2204 bearings are the right SIZE, but I didn't get into looking at load specs.
You'd also need custom centering spacers to run the KZ wheel, and may also have to mill down or add a spacer to the cush drive to get chain alignment.
all in all, not impossible.....but also not just bolt-n-go.
I think I have a KZ mag front 19" wheel kicking around, if you need some measurements.
For all your gear needs, check out CityLimitMoto.com
DTT10 code for 10% off at checkout
Offline Joseph New York
« Reply #125 on: Jul 15, 2017, 14:18:15 »
Wish I saw this post earlier could have helped. I didn't read all pages so excuse me if I'm repeating something.
I have a '81 CB750C that I put GSXR forks on. I too wanted to keep the comstars or a mag like wheel too. Mainly because of size and I don't like the look of GSXR wheels on a CB. When I started putting things together it became apparent that there is no way of getting the calipers to clear the comstar bars. I decided to have ISR in Sweden make custom rotors for me with 5 bolt holes, GSXR caliper offset and size, as well as buy an OEM '83 CB750SC mag wheel off eBay. Then I bought a 15mm x 10" dirt bike axel and machined two bushings and a spacer. All in all for me to keep a 18" CB mag wheel, with parts and machining cost me around 500 all in. Custom rotors was the most expensive part but they are very good discs. If your sad about having an 18" wheel over the 19", know that because of the caliper's share line, the 18" barely make it and require a little tie-back if it worries ya. But much better looking than the GSXR 17".
If you want any measurements in creating the axel and rotors let me know.
Good luck!
« Last Edit: Jul 18, 2017, 17:19:45 by Joseph New York »
CB(500/4|650|750|750/DOHC)
Norton Atlas
Suzuki Savage bobber
Offline rs_ss350
« Reply #126 on: Jul 26, 2017, 09:59:23 »
Thanks Joseph New York - yes SC wheels was one of the options I was thinking... however i just picked up a GL comstar which is the earlier version of the comstar.  JUst got back from vacation, and will be going to the shop tonight to size it up - fingers crossed!  They are 19 wheels, and i did notice the share line might be an issue, but I figured I could probably find or have a longer line made if needed.
« Reply #127 on: Jul 26, 2017, 12:20:06 »
Well the main issue with comstars is the radial calipers clearing the sheet steel, it doesn't even come close to clearing and you can't shim radial mount calipers longitudinally like you can standard mount calipers.
Unless for some reason the comstars you found don't angle out as far toward the axel, but if they didn't I wouldn't imagine they would hold up very well. They are thin folded steel. Or if you had a really old GSXR front end that had standard mount calipers you could shim and space, but I'm not even sure that would pan out without some welding and cutting.
You'll def need a longer share line, my 18" only has 1/2" clearance which scares the shit out of me and I'm working on a longer line or tether.
Cheers
Norton Atlas
Offline crazypj
« Reply #128 on: Jul 26, 2017, 13:13:40 »
You could always shim them directly out and use large diameter disc rotors (assuming you don't already ave 320mm?)
Brian Morgan, 1982
« Reply #129 on: Jul 26, 2017, 18:19:42 »
My calipers used 310mm, his could be 320... Yeah, long shim/extenders could be the only only way to get comstars to work IMO, why I didn't do it was because the rotors would have to be enormous and was worried the shimmed extensions would make the mount less sturdy. Plus machining 4 extra long mounting bolts which would cost an arm/leg. I'll def stay tuned if the PO attempts this...
Norton Atlas
