Titan performance
Titan cafe racer builders.
Ps.......purple and white !
This is true if the vapor is made from soda. silicate vapor will damage, my guess is you have a soda based mix for delicate items.Benjo@EKCMC said:Hi yes I did the crank case internals as I beleive that the vapor blast process does not damage the surface like sand blasting would. We use the blaster at work for all sorts of delicate surfaces on parts of electric switch gear with no probs.
Maritime said:This is true if the vapor is made from soda. silicate vapor will damage, my guess is you have a soda based mix for delicate items.
