UK Mark said:Picked up my engine today and bolted it in loose with temporary studs as I'm waiting for a new set to arrive. So glad I had the barrels blasted and powder coated as they look loads better.
Also sorted my gearbox as the kickstart shaft I'd fitted from a T150 made the lever stick out way too much compared to the original slick shift item. Must be at least 3/8, which doesn't sound much but just wasn't right.
Trimmed the gaskets and polished the casings, but also shaved off a projection in the casting on the centre casing that used to hold a gear indicator. This wouldn't work on mine after changing out the old 4 speed cluster and it also interfered with the oil lines, so I filed it off and cleaned it up. The casing still has the same section thickness, so it won't have weakened it. Clicks through all 5 gears nice and smoothly, so I'm happy with that
UK Mark said:You can buy an off the shelf kit for a modern Triumph that could be adapted to ours, seeing as yours has the same frame. Plus also an old TZ type that would be cheaper, but this just needed a tab welding into the upper frame tube. I bought a stanchion clamp from Minnovation Racing and it was a simple mod. Thought it better on the left hand side as it can be adjusted better with a right hand on the throttle. I see quite a lot on the right and it can't be as easy to adjust on that side.
UK Mark said:Made a couple of throttle cables up and fitted a Domino TZ type throttle which is much better than my old one. I bought a pair of Renthal bar ends quite some time ago, so nice to fit grips and those.
UK Mark said:No not a push / pull, but search the net for a Domino Twin Pull Throttle and you'll find prices and info.
