Ncstatecamp
Crank shaft and arms
Tranny
shift forks
drum
shifter arm levers
Rear shocks
Piston set
Cafe hoop
Kick starter arm (off set)
Bobber kick stand & spring
Rear brake actuator
Start motor cover
Head light bucket
Carb bodies (3 various conditions)
Horn (working, metal chrome, ehh surface condition)
Fork ears set (left dented)
Wheel spacers
Valve cover
Cam chain tensioner
Cam chain wheels
Can chain guide
Front sprocket cover
Rear sprocket guide (slightly chewed)
Cases good condition-
Tail light bracket
Points plate
ape hangers
bearing holder circles
oil pump
axel stop blocks
chrome axel adjuster brackets
fuse block
breather cover
break dust cover
speedo (painted covers)
tach (all parts slightly disassembled)
All parts are cb750k
If you are in the area and are interested in all of it, let me know too!
Im moving and need/have to get rid of it and would really feel bad about scraping stuff
Tranny
shift forks
drum
shifter arm levers
Rear shocks
Piston set
Cafe hoop
Rear brake actuator
Start motor cover
Head light bucket
Wheel spacers
Valve cover
Cam chain tensioner
Cam chain wheels
Can chain guide
Tail light bracket
Points plate
ape hangers
oil pump
axel stop blocks
fuse block
breather cover
break dust cover
