clay69camaro
Active Member
Bike fired up last night, sounded good with a real easy smooth idle.
The T's that connect the center carb to the right and left leaked fuel though. So I ordered them up (really really not cheap) Also ordered up the butterfly shaft seals, might as well replace them if I'm going to separate the carbs right.
Bike only started with the choke pulled out. Is that typical? It's not cold here in Southern CA. or do I just need to work on my jetting when I get it back together.
Thanks
Thanks
