Couldn't tell ya.CJDisaffected said:Bump!
It looks like this is the inner spider from a cb350/360/400 disc bolted to a modern outer. What is the model of the outer disc?
I'll try and find out for ya.CJDisaffected said:No big deal man. That image opened a whole new line of ideas for a me and my buddy. I will post a new thread once we get a little closer. Thanks!
Here's what I found out:CJDisaffected said:No big deal man. That image opened a whole new line of ideas for a me and my buddy. I will post a new thread once we get a little closer. Thanks!
I don't know. All I can tell you is the guy is about my age (62) and he was the WERA Champ in 08 I believe, so it must work for him.grcamna5 said:I like how the caliper bracket was fabbed and then bolted to the existing threaded holes on the lower rather than welding the cast alum. w/ a special bracket and hope that it'll stay on.How does that BMW 'K' bike caliper bite down for him Marc ?
o1marc said:Here's what I found out:
The hub I already had an alloy rim laced to was a 4 bolt CB350G [disc brake] for which not much is available--but
the CB350G rotor consisted of an alloy carrier riveted to the actual disc with 6 rivets....I found a Yamaha match for the bolt circle.
"It's a larger diameter disc than required but the big diameter gives you more spoke /fork clearance for the caliper [I used a Brembo from a BMW K75]
All this was the long way around the barn--there's better hubs to start off with.....there's a brake co website somewhere that gives extensive replacement rotor dimensions"
It is an EBC floating rotor replacement for a Yamaha rotor.
