biker_reject
Over 1,000 Posts
Very cool, very cool!
trek97 said:Its looking really great. Have you tried fitting the chain to it ?
The swing and tire are monsters.
trek97 said:Nice. Seen a number of guys do a ton of work and in the end they say "DOH!!!" didnt consider a chain went on this thing. Its crazy how easily things like that can get overlooked.
Im glad you had it in mind from the start. Thats more than half the battle, WON.
pukhkan said:Awesome build bananas!!!
been there forgot to consider air filters on my bike
bananas said:Another thing, I've planned to add a steering damper as a safety measure so I picked up a stock 2001 GSXR 750 unit hoping to use the stock lower triple mount along with a extra large steering stop. Turns out the unit isn't long enough to fit.. tried a bunch of locations as well.. Anyone know a decent (and relatively cheap) steering damper that is somewhat longer than usual? I'll mount it under the headlight on the front end or perhaps somewhere on the frame..
750mors said:Looking good bananas, any chance you could post a pic of how you did the top shop mount? I'm about to tackle it on my build and looking for ideas and inspiration.
Matt
cklamer said:That is what I did with my GSX1300R Hayabusa front end.
Welded on the larger bump stop and will use the stock damper mount.
I will be posting picks of my finally finished Version 2.0 build soon.
xb33bsa said:bike looks great !
i wouldn't worry about a damper though with the stretched wheelbase and increased trail it should be as stable as an oil tanker
alexfisher7 said:HI bananas
Good job indeed,
I am looking to do a monoshock conversion myself. Beside the all monoshock fitting/fixing malaka, how easy was it to fix the gsxr swing arm? any mods needed on bearings and fixings?
I am up for mods on the frame itself but don t have the gear to work aluminum so....
DylonDylonDylon said:Those lines are looking clean!! Love it. I'll be stopping by and checking often.
bananas said:Thanks Matt. Love the build. We DOHC owners have got to show up those inferior SOHCs! Its funny.. I've been building this for over 2 years now and you're way ahead of me -- awesome!
Here's a photo of the shock mount (best I have on me -- out of country and away from the bike). Its basically a series of gussets, about 2.5 inches down, connected to the stock horizontal brace/tank mount location. Originally we had created a mount directly to the tank mount -- however the bike ended up having about 3 inches clearance and mushy suspension travel. It functions well at the new location, albeit stiff. I'll get more photos of it in the future but I assume you've figured it out already!
Thanks bananas, yeah I've roughly figured out my mount. Just need to cut up some gussets for extra strength. I'm worried about the rear height but it's going to be a trial and error situation I think. I've used an earlier shock which is only 300mm so I've got other options for longer shock if needed.
What shock are you using and have you looked into spring rates?
Represent the DOHCs! Haha
Matt
750mors said:Thanks bananas, yeah I've roughly figured out my mount. Just need to cut up some gussets for extra strength. I'm worried about the rear height but it's going to be a trial and error situation I think. I've used an earlier shock which is only 300mm so I've got other options for longer shock if needed.
Matt
