Author Topic: Did I buy junk?  (Read 1339 times)
Offline doc_rot
Did I buy junk?
« on: Apr 02, 2018, 04:24:26 »
I recently bought these used hard welded and reground cams for a kz750 sight unseen. When they showed up the bearing surfaces and cam lobes were covered  in a waxy grease. After removing this I am dismayed to find there is substantial rust and pitting on the bearing surfaces and the base of the cam lobe. Are these trash?
« Last Edit: Apr 02, 2018, 05:38:06 by doc_rot »
Offline J-Rod10
    • Slipstream Cycle Works
Re: Did I buy junk?
« Reply #1 on: Apr 02, 2018, 09:30:41 »
I'd return those if possible.
Online canyoncarver
  • 'hacking is learning'
Re: Did I buy junk?
« Reply #2 on: Apr 02, 2018, 12:05:36 »
Yeah, return.  I wouldn't run them.
73' The Commando
YZF750/1000R The Fly
KZ 750 Twin
ZRX 1100
KZ400 The Rabbit
KLR650, more Nortons, a BSA, my 93" shovelhead chop, an 86' FXR, and an F9 Bighorn
Offline WhyNot
Re: Did I buy junk?
« Reply #3 on: Apr 02, 2018, 13:07:35 »
Pitiful, just pitiful, what some will do to others for a quick buck.
Geeesh. Send them back with a very sternly worded note.
2006 Harley Davidson Heritage Softail
1975 Honda CB750K5 needs carb work
1974 Honda CB350F2 needs tins painted (being lazy)
1972 Honda CB175K2 roller no engine
1972 Honda CB/CL350 Engines need roller
1972 Honda SL350K2 Frame for above engine
1972 Honda CB100K2 needs kicker shaft
1990 Mitsubishi MM needs engine rebuild
1984 Dodge D50 Beater DD since 1997
Offline teazer
Re: Did I buy junk?
« Reply #4 on: Apr 02, 2018, 14:15:39 »
Sorry to confirm what others have said more politely, but those parts are junk.  That is some serous pitting, so I am not sure why anyone would have ground them.  Possible that the grinder did it to show the owner that they were junk.
If they were the last pair in the world, I'd get them media blasted and metal sprayed and ground to spec, but I'd hazard a guess that there are better cores out there.
Offline doc_rot
Re: Did I buy junk?
« Reply #5 on: Apr 02, 2018, 14:25:30 »
crap. that's what i figured. They are a Megacycle cam with a pretty radical .465" lift. I talked to them and they said they could repair it for $400 but for that much money I would prefer to pay a little more and get a milder grind.
Online canyoncarver
Re: Did I buy junk?
« Reply #6 on: Apr 02, 2018, 16:04:09 »
Yeah, IIRC, they quoted me 450 for a new set if I provided a set of cores.
73' The Commando
KZ 750 Twin
ZRX 1100
KZ400 The Rabbit
Offline doc_rot
Re: Did I buy junk?
« Reply #7 on: Apr 02, 2018, 16:13:26 »
I guess their prices have changed because it's $688 now
Offline crazypj
Re: Did I buy junk?
« Reply #8 on: Apr 02, 2018, 17:13:57 »
I think Megacycle just pull numbers out of their asses?
 Prices seem all over the place and have for several years.
Personally I feel they are just severely overpriced as cam grinder is same as automotive one ( swapping templates around doesn't seem that difficult from what I've seen) Specialising in motorcycle cams will be a bit more expensive than knocking out a few hundred small block Chevy cams but not the amount they want.
Best thing I ever overheard
Brian Morgan, 1982
Offline doc_rot
Re: Did I buy junk?
« Reply #9 on: Apr 02, 2018, 17:31:18 »
seems way over priced. Do you have any recommendations on other companies? Or may be I should just keep calling until they give me a good price. lol.
