Hello from the UK
Perhaps I should change my username to Jammy Dodger.
This has gone pretty well so far so I’m guessing it will blow up when I come to ride it, just to keep the universe in balance.
Love the look of the swingarm fins. And the utilitarian in me can't help but think how useful the extra tie down points would be in transport
Yes,
It is a bit OTT.
Dropping the tank off tomorrow 2 my mate Colin who is a traditional sign-writer.
He used 2 paint F1 cars before vinyl graphics were invented.
The bloke is a genius & never fails 2 impress.
Still waiting on the tank.
Will be a couple of weeks at least.
I’ve got a load of 1.5” + 2” stainless fittings kicking around...
So I will begin to think about the exhaust soon.
This the “back of a cigarette packet” sketch I done earlier for a flat silencer for beneath the engine...
Sheet the top, bottom, do the inlet collars, drill & weld the outlet tubes.
Went for 1.75” dia in the end as it’s the same as the down pipes & I have more of those fittings about.
It’s got 2 chance & the 2nd is the scrap bin !
Interesting and innovative. I would suggest leaving a way to access the inside - at least temporary - in case adjustments are needed. Two questions - 1) any reason for five outlets per side? And 2) do the outlets sweep up or down?
Hi,
I did a bit of maths on this...
The inlet is 36mm inside Dia.
Cross sectional area = 1,017 mm2.
5 X outlets at 16mm inside Dia.
Cross sectional area = 1,005 mm2.
Just about the same.
Going to make the baffles at about 650 mm2 to restrict the flow.
I haven’t worked out the volume of the silencer box + down pipe but hopefully it will be enough to have an effect.
If not, I may have to consider trying a balance pipe on it but I want 2 avoid that if poss 2 keep it in stereo.
It can’t be any noisier than what was on it before. (2>1 straight through)
There is probably a tried & tested formula for this stuff but as it’s a “hit & hope” kind of project, I’m happy just winging it along.
Gonna mount the box so the outlet pipes point downwards.
They were 3/4” 90 degree elbows before I sliced them in half.
Just using up what I’ve got left over on the shelf.
Hopefully I will get a few more hours on it later today.
Just thought,
If I need some more back pressure I could block the odd outlet hole or two up.
It would be like playing a musical instrument.
I got impatient so I welded 1 side on to see how it looked.
Not that it matters much as most of it won’t be seen.
Can you add something to either side of the baffle to absorb reflections? Also, the top and bottom mighte be come resonators, so consider deadening them somehow. I;d still try it with top or bottom temporary until proven. Suspect that just an opening between sides would act as a balance port.
Hi,
Thanks for the comments & suggestions.
The top & bottom plates are 2mm thick so shouldn’t move too much.
I am thinking of adding a second chamber underneath to increase the volume which should help it.
Defiantly going to test it before I fully weld the bottom plate on.
Started on the downpipes ...
