Post a pic of something you made!
ncologerojr
Coast to Coast
DTT BOTM WINNER
DTT members come up with a lot of cool stuff, but it’s easy to miss combing through all the build threads.
Post a pic of something you’ve made that you’re proud of, or just like. Doesn’t matter if you’re a beginner or seasoned fabricator. Inspire someone else.
I've got a few things I'll toss up.
1st is velocity stacks that mount actual air filters.
2nd is hydraulic clutch slave for an xs650
3rd is hub/rotor adapter to use a cb550 hub and ducati rotor with a zx6 big piston fork front end
And last is a tube bender using prints from this site http://chopperhandbook.com/bender.htm
I did use a waterjet for part of the tube bender, and a cnc lathe for the velocity stacks. But the others were done on an old atlas lathe and a manual mill.
I like this a lot, but for the sake of thread redundancy, SONIC. started a thread with much the same criteria a while back.
http://www.dotheton.com/forum/index.php?topic=57318.msg648839#msg648839
I don't mind another thread, especially since the traffic can only do the site good. I didn't build any of this stuff this week. This week, I am fighting off a hurricane turned tropical storm.
A couple of tail lights...
A hand-stitched seat...
fair enough, ill join too then. These are all over the past couple years. My projects seem to be a litte heavy built due to my profession as a heavy structural fabricator and welder lol
Decided to build up a wheel truing stand out of extra material I had laying around. I had to buy a chunk of all thread, but still the cost was less than the harbor freight unit. She is pretty rigid lol.
Built this table my old southbend lathe, belt sander and drill press. Built from scrap steel laying around and a butcher block maple bench top saved from the dumpster. A little sanding and urethane and it turned out pretty nice.
I also built up a quick and jakey hammock stand that fits in the reciever hitch on the silver-ay-do.
J-Rod10 said:
That benchtop lathe is sweet.
Thanks man, I was happy to be able to buy it. After a cleanup and rebuilt, if you do everything right, it'll still hold a half thou over a 4" long cut on the o.d.
I can't complain a lick about that
I’ve got the same lathe, love it.
Yeah, I thought it would be cool to start it up again without any timeline. I think it allows people to dig up older pics to showcase things they’re proud of.
Nice work!
Nice projects. Nothing wrong with heavy in those areas!
Nice work. I love spending time on my south bend and manual Bridgeport, but I would put a water jet and cnc to use if I could!
Thanks, I just took advantage of working at a company that built water jets, then when I changed jobs I ended up programming and running a pair of live tool lathes. Now I have a better job, but can't run anything under the table. Now I'm limited to an Induma mill, and the old atlas 10". But after seeing the work bench posted earlier I need to quit waiting and build a better one.
Not really "made," but I've been tinkering in solidworks after work for the last few days knocking up a hossack front end concept. Haven't done any proper linkage calcs so don't read too far into the kinematics. Also, I know belt driven steering is a bit on the sketchy side...
I'm planning on doing an actual hossack build probably next year, but it'll be all tubular steel. This is just a bit of fun.
No fancy metal work or anything going on here, but I made my own damping rod holder out of 1" PVC. I heat the end with a hot air gun until pliable, forced it over the end of the cartridge until it set and then ran it under cold water to harden it. Then I drilled a hole through at the other end to stick a screwdriver through to help hold it in place while you loosen/tighten the bottom bolt. Works great. This was made for a set of 43mm standard forks.
I got the idea from another forum I'm on.
I just got my shovelhead split tanks repainted so I need a new tank bib. I went to Tandy leather, they give a great discount to military, vets, and first responders. I got a few leather punch tools, needles and things. I got some new leather and lacing and did this over a weekend. They even had some cool pins that were perfect for what I wanted.
