3DogNate's XS650 Bobber - DONE!!!
I switched from the stock BS34 carbs over to a set of CVK carbs from an EX500 Ninja. With 40Pilots/140 Mains/JJJ needles it's running great. So much more responsive than the BS34s and no problems getting to red line...
Back on making my 650 as good as I can make it...
Today am yanking the (still in working order) TCI ignition and stock charging system with a Pamco ignition with E-advance and a Hugh's PMA. Just wrapped up the Pamco install and am onto the charging system... Gotta hit up Justin for his stock puller.
While waiting on the flywheel puller to become available I turned a pair of aluminum exhaust tips on the lathe...
Update:
Added Pamco w/ E-Advance
Added high output PMA alternator
Removed electric start
Removed battery
Swapped handlebars
New front master cylinder
Add aluminum exhaust tips
trek97 said:
What? you take breaks between island vacations to work on the bikes?
Gotta do something to relax from.... Need an excuse to get away from the corn fields and flat land...
I got out today and broke in the PMA/Pamco and finally got to test out the new bars and seat. Man this thing rides TONS better now.
I rode out and took some photos out on a little stretch of the original Route 66 in Towanda, IL...
