Gs550 Cafe racer Update 19/4 2015
Nugiz
Active Member
Here is my project still a little work but i think its finish about 1-2 month
369194-cafe-projekt-
369204-cafe-projekt-
369191-cafe-projekt-
369193-cafe-projekt-
369201-cafe-projekt-
369200-cafe-projekt-
369186-cafe-projekt-
369202-cafe-projekt-
369188-cafe-projekt-
369196-cafe-projekt-
369198-cafe-projekt-
369185-cafe-projekt-
369207-cafe-projekt-
369190-cafe-projekt-
369192-cafe-projekt-
369199-cafe-projekt-
369187-cafe-projekt-
369206-cafe-projekt-
369203-cafe-projekt-
369209-cafe-projekt-
369208-cafe-projekt-
369205-cafe-projekt-
Re: Danish Gs550 Cafe racer
Nugiz;
Very handsome seat, and excellent paint on tank and seat, will be watching this build.
Thx. Soon there Will be more pic. Tomorow the tires and rims are finish. 3,5"x18 speedmaster. And 4,5"x18 Way Master rear. On spoke rims
Loving the tank and seat!
That rear tyre though...that's going to be shit scary when you tip into a corner...it's like a knife edge! Looks more like a car tyre with that flat profile.
Fairly sure it is for a sidecar...
At least all the area of the tyre will contact with that seat hoop.
The bike is only made to City rides ;). So no curves only crusing. If i want speed and fun ride i have never choise an gs 550.
Jes the rear tyrer are is s car tyre i Think it Will look sick :)
You really shouldn't be choosing tyres for a motorcycle on how they look.
To me it looks dangerous.
369486-cafe-projekt-
this is what i use if i need performance and wild turns, i can't se the rubber problem its not flat on the top its curve a little ;) but thanks for the cons urn
If you lean your bike even just 10 degrees you will see it will be riding on the flimsy squared off tread right at the edge of the tyre.
You're kidding yourself if you think you are only going to ride this bike completely upright unless you are just pushing it in and out of the garage.
I belive In you. The rear curv a lot when air gets In. But thanks and if its slide then its easy fix just buy an firestone champino delux or cooker ;)
cool looking bike but the tire hits the frame loop you put too low and too far forward
First of all, the bike is not comprehensive but only set up and form a picture of where I'm headed towards . swing arm is extended and behind the springs need to be higher so the angle of the bike also gets really ;) , the wheel will never frame and the rear frame I put rubber pad into the rear shock as bump stops . but thanks for the input the fat is so helpful ,
look at the picture the rear wheel is also turn the wrong way the brake is in the wrong side;) its only to see the look;)
cool, i get it it is is a bar hopper, coffee shop bike ;)
those are koni's ?
