cb seven fifty rc42
BENJAMIN
So back in 2012 i started on my cb seven fifty rc42 café racer Build. Back then i chopped a whole bunch of the frame... A big mistake cos now im struggling with thé subframe. This is how she sits now.
Now i have absolutely no idea on where tot start...
This how i want things to look :
Any ideas? ( I don't have access to a pipe bender. Welding is not a problem)
Sent from my ONE A2003 using DO THE TON mobile app
You can buy pre-bent rear "hoops" based on the distance between your existing shock mounts. I would just weld straight tubing from the backbone to the rear hoop.
1+ to Brotus, I'd get the hoop so you can be sure you can align the laterals and hoop. Also think about whether you want to stash electrics in a box between those rails and if so, make a cardboard mockup and think it through. Cardboard is cheap. But don't get "writer's block" - it's not like you've trashed this puppy, just get on 'er. Spring is coming!
