if you still have the ears attached to the forks simply measure the space between them
if the forks are out of the clamps then measure the distance between the middles/outside ( depending on the offset of the clamps from the centre of the tubes) of the two holes the forks go through in the clamps
even though i know little to nothing about the 350 i'd say it is unlikely a 7" will be the right size, its fine for a 750 but the 350 would be a fair bit narrower in the front end? at a stretch a 9" can be made to fit a 750 but you'd only do that if you were after an improved set up which seems to scare some people, as does using a 90/110 H4 halogen, can't think why people would actually seek out an original sealed beam
