Does a bigger tire always mean a bigger tube?
I went to the irc site to check. They said "L" for that tire.
Still, I would get a better tire. the Duro tires are $100 a pair. They are cheap but still much better then the scooter tire and higher speed and load rating.
it's your skin though, do what you think is best for you, but you had doubts or you wouldn't of asked. Go with your gut feelings.
Sent from planet Earth using mysterious electronic devices and Tapatalk
That's what I do, I've posted about it multiple times ;D
XS650 steel rear fits on CB360 hub no problem, it's what I did with Brendon's 360 until he decided to get a pair of black anodised alloy rims
If your going to paint them it doesn't matter if they are rusty (in fact, rust is probably an advantage, less chrome to clean off ;) )
Thanks pj, I have a couple sets of extra rims lying around the garage. Also I am using a front drum setup.
XS650 rear drum is almost exactly the same size on spoke hole diameter as 350/360 front drum ;D
You'll be fine using a steel rim with drum or disc
