Ya... This thing....Special just like Olympics
One fender down one to go...also stealing the SR250 original rear shocks and using a turn signal for a tail light
I think so the back of the headlight says 8v
Just finished the other fender need to go get some primer
Are you going to use the bike piece as a tank? Or just as a piece to mount one?
Sent from my MB525 using Tapatalk 2
So is that bike frame tube steel?
Looking rad so far!
You should bring it to ThunderDrome!
looks like a sachs engine?
Check out treatland and 1977mopeds.com
If you get rid of the engine I will give you $15 for it.
Im building a motobecane moped chopper right now.
not to thread jack, but here is a picture:
it is mcdonalds themed
Haha.
deja vu, I've been here before. deja vu, I've been here before. deja vu, I've been here before.
This is a cool project, hombre.
Right now I'm having amnesia and deja vu at the same time. I think I've forgotten this before.
~kop
....Epic.... where is your build thread? Also treatland is where i got the puller i needed to find out i'm a moron and didnt have spark because the vice grips were grounding out on the frame
The mongoose tube is aluminum.....the plan is to get it to bolt onto the frame for added rigidity and a place for the tank to sit...I just got acetylene tanks and torch setup the other day just need to fill them and i can start welding the tank....since it will be my first tank i went with an "easy" one as my inspiration long and flat like this one here
ARE THOSE BICYCLE HANDLE BARS?
Got them at the used motoshop a town over...they normally dont have new stuff but they bought out an old dealer so they had these clubmans ......they're too small for a motorcycle but perfect for this
Things are cleaning up nicely top triple before a buff and spit shine
no build thread for the moped, its too sporadic haha.
you could easily find a steel tube to weld in there. maybe cut a junk trampoline? idk.
seriously though, lemme know if you get rid of that engine!
cheers
If i sell it probably will be more than $15 but ill let you kno
Bit more paint and started messing with pipe options
