1972 Nopar Volksrod Hellride
Figuring I wanted to build a motorcycle influenced exhaust. Still have work to grind those pie cut welds back.
Quadrajet is the same carb used on the GMC motorhomes and all the Rocket 455 engines. It's a very good carburetor.
Exhaust looks great, that's a shit load of pie cuts.
At least at the strip you won't need tire warmers. Just sit there idling long enough and the muffler will heat the tires ;D
For the record, I got one side of the exhaust done last night. LOL . I was up until 3am hell bent on getting that side done. I swear I spent 4 hours and 40lbs of industrial mix welding up those cuts. LOL
Still waiting on material for the tail light trim, but here is a lens with LEDs installed...
https://youtu.be/wSk-yInWiWI
Metal finally came in so I could machine the trim rings...
I’ve had to reshape the tail piece a bit, and there’s still more to do, butt...
