Texas Two Step Taco
Are you doctor who with a tardis? That shed looks so small on the outside and yet it's huge on the inside. Almost looks like a fab shop. ;-)
Just a few rabbit holes.
Looking at these skateboard wheels for the Bultaco drag bike. 52mm abec 7 bearings 99A hardness. Also want to use one for our auto chain tensioner we need to fabricate.
any thoughts?
That's what I did...
So made our Clutch basket spanner
for the Bultaco out of chromoly.
Have been digging through the archives of Bultaco history and forums. So my M51 has the same close ratio gearing as the Bandido. Zeke’s M70 has a wide ratio gear box.
May have found out why I have a B61 Bandido frame...supposedly the M51 has the engine shifted 70mm to the rear which gave it a light front end. The B61 frame fixed this or it could just be Spanish steel.
Going to bore out the Chinese CRF50 rotor and taper tonight to make it lighter. Lol Zeke was telling me my rotor was too small and that I wouldn’t have any torque. I said, “that’s what your momma said and you turned out ok.
The Bultaco Bandido Montadero has two taper angles.
Instructions for the Chinese Racing Magneto with an internal rotor for the XR50, CRF50, XR70, Pitbike and Mini ATV Engines: XR/CRF 50, 70, Z 50, BBR, Thumpstar, SSR, Sikk MX. Most Chinese made and most HONDA Horizontal kick start engines,
Component:
that slings magnets up to 15000 rpms instructions said to connect it to the high pressure bag. Some things are just lost in translation
The Bultaco TSS 350, Bandido, and Montadero share the same all metal clutch plates. They have metal dimples that eventually wear off.
Looking at the Mikuni TM 38 Series flat side carburetor Bore: 38mm. Spigot Mount: 43mm. Main Jet: 230. Pilot Jet: 22.5. Needle Jet: 389 Q-2. Throttle Valve: 4.0. Jet Needle: 6FJ41
Along with this reed.
We made a perch for the air shifter and tacked it in place
Got the steering stabilizer installed and welded in place
How critical is dwell time on a Hall effects sensor like on the Dyna S? Can we install a magnet on an aluminum collar. Slide the collar over the crank and space the dyna s to accommodate the collar and magnet.
On a 160 Honda, we just machine the stock DYNA S rotor to fit over the crank end. You could also machine one from scratch and us the magnet from the Dyna rotor. It doesn't take much heat to eject the magnet. Then epoxy it into your new rotor
