so i get up sunday after a late morning nap, wander out to the garage -and thought i'd rough in one side of the head to figure out all the little details/tricks and then let the kid do the other side (with a few hints and a little guidance.)
(before i continue- just understand that we bought the bike as a mess. never rode it, had no experience with this exact make and model, and the only contact we've had with it was in teardown... which is often messy, too quick and overwhelming. sometime you take something apart and do not pay enough attention to some little detail that no one in their right mind would pick out unless they had done it before.)
with that said, I sat down to put the head together...
anyone reading this forum is probably intimately familiar with this graphic:
well, i sit down, assemble the valves, the torsion bars, the rockers out of their labeled ziplock bags... all is well. I pick up the cam and..
it doesnt fit.
i remember them being little bastards to get out (because we could not turn motor to relax the cam as cyclinders/pistons were rusted together) so initially, the difficulty didnt concern me. I just had to find the right angle to slide them in.
remember the above schematic? look reeeeeal close at the little arrow in the lower left hand corner.
see it?
the arrow points to the "FRONT" , which shows (for lack of a better description at this point-) the extra long cam goes in at the -opposite of the arrow- or, the BACK.
take another look at the schematic. and at the arrow. it shows the exhaust cam going in the "back" or intake position.
furthermore, the 45yr old, original, translated from Japanese technical manual is almost useless with its blurry black and white photos and Jing-Grish transaltions.
so after about an hour, I finally sat back and thought back about the process. I remembered the point and tacho on the FRONT of the motor -which was in clear contrast to the factory schematic.
anyway, long story/short: finally got half the head together -with the right cam in the right place.
here it is mid cam-shimming.
and btw- Honda Twins has a GREAT sticky about the whole process here:
http://www.hondatwins.net/forums/1-project-logs/11792-cb450-cl450-valve-train-assembly-pictorial.html
a small hint for anyone reading to take from this. well, two actually: the first is- sometimes those that should know -dont.
second is: when tightening the valve holder caps, slowly/gradually torque only the three bolts that form a triangle in contact with the cam socket/cup. tighten the fourth (longer) bolt last. This ensures the holders go in straight and parallel and the cam will turn freely.
Tightening that longer bolt can put the slightest twist to the holder and bind the cam.
took me a few tries to figure that one out.
some chassis bits showed up! time to button up the roller.
