XS650
kopcicle
antidisestablishmentarian
From early on, Shell would butt heads with the Japanese engineers. The newly designed Yamaha twins kept blowing oil out the breather. The specs called for 3000cc to be put in the crankcase. Shell told them right up front it was too much and they needed to put in 2500cc.The engineers would try all sorts of baffles and orifices intended to reduce the oil loss, but to no avail. Shell continued to put in his recommended amount until finally the factory engineers followed suit. You can look at the imprint on top of the cases and see the reduction in oil requirements over the years until it settles on the amount advised by Shell.
Many thanks to the 'cafe once again
http://thexscafedotcom.wordpress.com/ in case you haven't been there .
~kop
