work9to5
See you in the wind.
Hey guys, I recently swapped on a gs550 swingarm/rear tire/disk brake setup on to one of my cb550's. I'm thinking I want to swap in the front rim as well, just to get the matching look. The current rim is a spoke while the back is a five point mag. After doing a little research I've found that the stock gs550 mag wheel is 1.85 and so is the CB wheel, also Suzuki and Honda had the same 5 point rotor mount holes. Do you guys think this would be a direct swap? Able to fit on the CB front axle without machining spacers and that the single brake rotor would fit?
