SONICJK
Reminds me of...me No, I'm sure of it. I hate him
So do IRich Ard said:We have this bender if there are any pics or measurements I can take that would help.
Don't get me wrong it's a great bender!Rich Ard said:Ha. We just figured out where to bolt it to the floor - didn't realize it had such a limited radius.
ain't scared,lolSONIC. said:Party at my place, and junior volunteered to be the first to use the new bender! No chain guard of course because those are for pussies 8)
SONIC. said:Alright guys as you know I bend seat hoops and stuff.
I use a JD2 Model 3 bender that I just converted to hydraulic with an air over hydraulic ram.
I hate it.
It has to be stopped, disconnected and the ram pushed back in 3 or 4 times for each 180 degree hoop.
Manually this was no big deal but with the ram it makes each hoop take forever, the opposite of why I "upgraded" the stupid thing.
SO with this in mind I have been designing a new bender based on the JD2 M3 die set.
This is what I have come up with and I would like you guys input here on any glaring flaws you see in the design
Basically the through bar through the bender and die now is connected at the bottom to a sprocket, the sprocket is engaged in a chain that is connected to the ram. When the ram is actuated the sprocket turns, turning the die and bending as a result.
There's a spring attached to the other end of the chain so that when you release the hydraulic pressure it will spring back to neutral position on its own.
This effectively makes the bender capable of doing 180 degrees in one shot.
The bottom section with the chain would be enclosed with some sort of chain guard to prevent injury if the chain were to snap, keep your fingers out, etc.
What are your thoughts here?
Roc City Cafe said:I think that chain would jump off the sprocket, have you looked at hydraulic motors instead of a cylinder?
if you're going to go chain, it really needs to loop around at least 180 degrees of the sprocket... maybe even getting a rack and pinion instead of chain would work better, or even welding the chain to a steel bar and using it and the sprocket as a rack and pinion?
deviant said:Is there a reason you couldn't just get Rack and Pinion gears from McMaster-Carr instead of using a chain? Mount the gear rack on the hydraulic cylinder.
jpmobius said:Your design with the two sprockets solves the side load problem, but halves the power of the ram: (for every inch the ram moves, the chain moves 2). The ram would also require a sprocket (teeth not required, but effectively a pulley). I suggest you think much larger sprockets. You will have space, and the mechanical advantage of larger diameter will be hugely valuable, allowing wimpier chain and wimpier sprockets for any given load. I think the chain "rack and pinion" will not be practical, as the chain will requires a lot more wrap around to work, not to mention you would only be loading 1 + tooth at a time vs many with some wrap. Think 180 degrees for reasonable power transmission.
