Stock headers after market slip ons?
brungeman
I have a clean set of stock headers on my CB650 but the stock pipes have some rot. Since the pipe doesn't completely disconnect from the header. Do you suggest I cut just past the merge point of the two pipes in order to put slip-ons on?
You can see how one header clamps on, but the other header runs straight into the pipe. There is that chrome cover/heat shield but no joint under it. should I cut it just behind there?
