plyzo
1970 Honda CL 350
Hello,
I purchased a 1981 RD350LC that had been sitting for 6 years. Cleaned up the carbs, put new throttle cable / oil pump cable. The jetting is all stock and idles and runs great through the gears but I never seem to hit the power band in any gear. I checked the plugs and they are completely dry. There is a bit of oil but its by no means black, they practically look new. I lowered the needle clip 2 positions down to make it rich and had no changes. Plugs still look the same. I tried to following the manual on how to adjust the oil pump but it is difficult to stop the engine at the right point that the pump is fully out. My thought is that there might be too much oil which is causing it to run lean if that is even possible. At this point I am thinking of just removing the oil pump or blocking it off and running some premix to see if that is any better. Anyone have some recommendations for me on how I can properly set the oil pump injector? Or what else I should test.
Thank you,
Miguel
Thank you,
Miguel
