'81 cm400 brakes
noble
Does anyone know of an available front caliper upgrade for a cm400, what master cylinder piston size is best? Also what pads and brake shoes are the best option for stopping power? Everything needs to be replaced anyways, may as well make it better.
Thanks
can you post a picture of the front fork where the present caliper attaches then i can tell you for sure
but this should work but i need to see your so if you decide to get this make sure you check the bolt spacing
http://www.ebay.com/itm/82-HONDA-CB650-CB650SC-NIGHTHAWK-CALIPER-FRONT-LEFT-BRAKE-99-/331041600015?pt=Motorcycles_Parts_Accessories&hash=item4d139df20f&vxp=mtr
I can't get a pic of my forks for about 2 weeks..found a pic of an identical set to mine. Just the stock forks.not sure about the spacing tho
