Have you done the checks in 9.3?
No, the SSR is a switch. If it is closed it is conducting and no potential difference across it. If it is open, then you will have potential difference across it. Consider it eqivalent to a plumbing system - voltage equal to pressure, current equal to flow, switch equal to a valve, the heater equal to a turbine powered by the water flow. Come to think of it.... get someone that understands electricity to check it for you. Your understanding is too dangerously low for you to be doing this.1fasgsxr said:So it stores and releases the energy?
