Blake's cb350 Cafe (Update: APRIL 10th Jetted,exhaust, all hard work done! PICS)
Color Scheme
  • Black on Black w/ Chrome Accents
    Votes: 2 14.3%
  • Black on Black w/ Black Accents
    Votes: 2 14.3%
  • Original Gold Orange with Black and Chrome Accents
    Votes: 10 71.4%
  • Total voters
    14
Re: Blake's CB350 (Glassing Seat....WITH PICS + PIPES + VIDEO)
VonYinzer said:
Good on ya for making your own seat bud. Looking good.Its a good idea to glass some support into the seat base. Adds a little weight, but make a much stiffer and stronger seat.
I dont get what you are trying to say...i intend on making a pan out of wood...maybe 3/4 inch thick... for support.
Swapmeet Louie said:
I like the pipes
Thanks Louie,
other guys have been saying they dont go with the "flow" of the bike... but i am begining to like them... I was thinking of doing a slash cut but idk now...
Take some flat stock. Drill holes in it. Lay it on the bottom of the seat, lengthwise. Pour some resin over it. Lay glass on top. Put a couple layers of glass over it and make sure the resin gets in the holes. Its thinner and stronger than wood.
What is flat stock my man?
sorry, im still learning how to do this thing. :) Thanks for the help though Von.
Flat stock is a piece of metal. 1/8" thick,inch or so wide would work. I like the pipes too. I really have an aversion to mufflers. IMO most mufflers are way oversized and look dorky as hell. Last muffler I put on a bike I made out of a stainless steel water bottle and stuffed with glass.The seat has nice lines to it too. Nice work
Reinhard said:
Flat stock is a piece of metal. 1/8" thick,inch or so wide would work. I like the pipes too. I really have a diversion to mufflers. IMO most mufflers are way oversized and look dorky as hell. Last muffler I put on a bike I made out of a stainless steel water bottle and stuffed with glass.The seat has nice lines to it too. Nice work
Thank you very much Reinhard.
I might slash cut my pipes... but indeed i hate the reverse megaphone mufflers
ahh my dads being stupid.. he wont let me cut my pipes ? i want slash cuts!
Okay Guys:
Things to do on my list:
-Get exhausts properly installed-
Put baffles in [ ]
Find a clamp setup or weld the pipes together [ ]
Take whole exhaust setup to get sandblasted and painted. [ ]
Reinstall exhaust with copper rings and properly fit them [ ]
Weld on Exhaust Guards ?? [ ]
Fix Leaky Petcock [ ]
-Buy grips for handlebars (in black of course) [ ]
-Pod filters with a touch of chrome (K&N or Uni??) [ ]
-Finish, Mount, and Paint Seat [ ]
-Upholster the seat [ ]
REJET CARBS FOR NEW EXHAUSTS AND INTAKE** [ ]
Buy New Chain and Sprocket (i need suggestions on where to buy) [ ]
Degrease Swing arm [ ]
Degrease Everything Else [ ]
REGREASE Everything that needs it [ ]
Rearsets [ ]
Change fork seal oil [ ]
Change fork seals? [ ]
Finish Polishing Cases [ ]
Polish Drum Brakes [ ]
Polish Forks [ ]
Install my battery [ ]
Find Brake Light [ ]
Find Horn Button [ ]
Find Front Brake Switch [ ]
Reinstall Kick Stand [ ]
Uninstall Center Stand [ ]
Double Check All Wiring [ ]
Double Check All bolts for Tightness [ ]
Anything i forgot?
Not much to do since i cant get to sandblasters today.
First of all for my seat pan i tryed drilling holes out...and much to my failure the drill was getting EXTREMELY too hot for me to continue.. i think the metal was tooo thick.
I stopped with that piece of metal through it out and got a scrap hood out of my back yard we were gonna chuck anyways...we cut out a piece of metal from it...took it too the brake and then bent it to fit into my first to layers of fiberglassing.
reinforced the inside of my seat with another 2 layers...this time using mat instead of cloth.
grinded out a spot to bondo in later...for the rivets to attach the structure plate inside the seat..
put 2 sets of 2 small rivets then i put 2 BIG rivets with screw holes that i can attach it to the frame with.
found somethings i could probablly use for my exhaust clamp but it was at a swap meet so i dont know what theyre called...
Any help attaching a flared pipe to a 1 1/2 in OD pipe?
Re: CB350 by Blake (NEW PICS!!!!!)
also found a sweet 919rr for sale :b who wants it....?
its in rock island illinois if you guys can hunt down the number...i didnt get it.
For the paint, I'm going to urge you away from the black on black on black on black on black... I love black myself, but so many people overdo it. It's easy to black everything out; come up with some interesting, appealing color combinations and make it stand out!
That being said, it's your bike, do what will make you happy. That's just my more-or-less insignificant opinion. :)
Having cost in mind...
and conflicting with myself several times...
I cant bring myself to kill the vintage paint...its just damn cool.
Im going to have my buddy paint my seat to match the tank this weekend! :)
I am glad to hear your keeping the paint....I love the factory colors and it's show of age!
Yep...im still in foto shop mocking up paint.
ariel.714 o/c said:
man sounds good with just the heads . did you end up just running it like that?
it'll burn up my engine. I need back pressure I'm pretty sure
