73 CB100 Tracker Build
Dude that seat is fucking killer man.. did you do that yourself or have a guy do it? I rly dig it
Thanks! I am pretty happy with the way it came out.
I made the seat pan and had a bad sort of rough foam layout, and I also supplied all the material to a local upholster and he did a great job.
That seat came out great, I have an old poncho I've been thinking of trying to incorporate into a seat....hadnt worked out though.
Been a little while since my last update but I think its about finished.
I had to recently replace the points, replace cam chain since I could hear it, swap out the carb again and lined the fuel tank. Took a bit of time getting the timing right but when I did it fired right up!
Was able to ride it for a few miles the other night and it runs really strong, idles great and rides pretty good.
I will try and post some "final" photos here soon.
Here she is.
She's a real sweetheart bud. :)
I like the forks, How did you address the front hub (brake) stay?
You may be better off w carb tune, running a uni-filter or k&N.
And you could probably lose the unsightly tape wrapping on filter too, as she's way to nice for that. 8)
Love it.......looks great.
Wish I could get mine going.
I like the forks, How did you address the front hub (brake) stay? Thanks, I just the stay on the forks, worked just like stock.
You may be better off w carb tune, running a uni-filter or k&N. I think I am going to take the tape off, seems like she is choking a little bit, I have a uni-filter too but it actually did not run as well compared to the pod. ???
Not sure why, but I think my left side case cover is leaking oil. Going to try Hondabond, anyone have any experience with that?
Went to the desert and had a buddy help me out with a few photos.
Really is a good looker....................
I like it........think I said that b4......
Looks great. As for the Hondabond, yes. It works well if you can put a very thin coat on your side cover, let it cure for a bit and then reinstall cover with gasket.
Congrats on your BOTM nomination bud. It was a tough month, as you already know I like your machine and also the little blue/white 125.
Both nice machines. You both had me worried.
